Did they change the impedance of the inectors the sohc's use v.s the dohc's?
Im using the 323 injectors with my sohc ecu and they work just fine.....
b6t question
JWMotorsports
There are both High and Low Impedance 323 injectors out there. I'd recommend using a multimeter to check the resistance of the injectors both on your car and the ones your installing no matter where they came from or what they are going on. That is the only safe way to do injectors.
- cjthor
You take your multimeter and select Ohms/resistance...whatever the meter says. Put one lead on one pin and the other lead on the other pin.nos92mx3 wrote:Ok how would you go about doing that?
I have forgotten what impedance injectors the sohc mx3 uses, anyone care to elaborate?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
