Page 2 of 3
Posted: June 26th, 2005, 12:15 pm
by Talon_66
I bought a 1K resistor
Posted: June 26th, 2005, 1:44 pm
by babyblueMX3
mm adn you still have tach problems?...you sure you put it on the right wire ?
Posted: June 26th, 2005, 4:39 pm
by Talon_66
babyblueMX3 wrote:mm adn you still have tach problems?...you sure you put it on the right wire ?
Yellow/blue wire.
Posted: June 26th, 2005, 4:57 pm
by babyblueMX3
what diagram did you use ..his or mine
Posted: June 26th, 2005, 7:47 pm
by Talon_66
His
Posted: June 27th, 2005, 12:32 am
by PATDIESEL
Thanks BabyBlue for the diagram, I'm not sure anyone thanked you. I know I'll be using it.
Posted: June 27th, 2005, 7:52 am
by babyblueMX3
PATDIESEL wrote:Thanks BabyBlue for the diagram, I'm not sure anyone thanked you. I know I'll be using it.
hey np. I am not 100% sure though it will work fine. I will be testing everything once the MSD 6A comes here. damn shipping to Canada. It takes so much time.
Posted: June 29th, 2005, 1:49 pm
by babyblueMX3
Talon_66 wrote:His
did you end up using the msd tach adapter ? I'm wondering if you use this if you still need the 1k resistor
Posted: July 23rd, 2005, 7:53 pm
by babyblueMX3
ok I got the thing started today..works great except wacky tach after 5k
right now I'm using klze (7 nipple) disty (reallllly clean install btw), msd 6a, blaster 2 coil and transistor (tip3055) didn't use thhe hei module because I felt like I didn't need it. I'll post the correct info soon
Posted: July 24th, 2005, 10:06 am
by babyblueMX3
ok this is the diagram of my installation..It works good except no tach after 5k, I'm going to have to call msd for a tach adapter
Posted: July 24th, 2005, 5:13 pm
by timpronk
I've been in the wacky tach boat for a couple of years since I installed my crane cams with klze distributor and external coil. My tach drops to 0 after around 5000 rpm when floored. If its not floored it will climb higher.
I tried diff things with the resistor, but it still did it. I am no electrical smart guy though.
So keep us posted on the tach adapter.
Thanks
Posted: July 24th, 2005, 5:17 pm
by mdavis
I mentioned it on the first page but I will again, I had the same problem with the tach cutting out at 5k until I soldered my tach resistor in - but I'm guessing you soldered everything anyways.
Posted: July 24th, 2005, 5:57 pm
by babyblueMX3
mdavis wrote:I mentioned it on the first page but I will again, I had the same problem with the tach cutting out at 5k until I soldered my tach resistor in - but I'm guessing you soldered everything anyways.
everything is solederd and the resistor too
Posted: July 24th, 2005, 5:59 pm
by Talon_66
I still havent had time to fix my Tach issue, I will be soldering the connection when I have a chance.
Posted: July 24th, 2005, 6:05 pm
by babyblueMX3
I soldered mine..didn't change a thing
