wiring diagram (HEI/msd 6A/klze disty/blaster 2 coil)
I bought a 1K resistor
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- babyblueMX3
mm adn you still have tach problems?...you sure you put it on the right wire ?
RIP 400whp ZE-T MX-3
Yellow/blue wire.babyblueMX3 wrote:mm adn you still have tach problems?...you sure you put it on the right wire ?
- babyblueMX3
His
- babyblueMX3
hey np. I am not 100% sure though it will work fine. I will be testing everything once the MSD 6A comes here. damn shipping to Canada. It takes so much time.PATDIESEL wrote:Thanks BabyBlue for the diagram, I'm not sure anyone thanked you. I know I'll be using it.
- babyblueMX3
did you end up using the msd tach adapter ? I'm wondering if you use this if you still need the 1k resistorTalon_66 wrote:His
- babyblueMX3
ok I got the thing started today..works great except wacky tach after 5k
right now I'm using klze (7 nipple) disty (reallllly clean install btw), msd 6a, blaster 2 coil and transistor (tip3055) didn't use thhe hei module because I felt like I didn't need it. I'll post the correct info soon
- babyblueMX3
ok this is the diagram of my installation..It works good except no tach after 5k, I'm going to have to call msd for a tach adapter
![Image](http://img.photobucket.com/albums/v311/babybluemx3/wiring_msd_tip_coil_zedisty.jpg)
I've been in the wacky tach boat for a couple of years since I installed my crane cams with klze distributor and external coil. My tach drops to 0 after around 5000 rpm when floored. If its not floored it will climb higher.
I tried diff things with the resistor, but it still did it. I am no electrical smart guy though.
So keep us posted on the tach adapter.
Thanks
Thanks
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
- babyblueMX3
everything is solederd and the resistor toomdavis wrote:I mentioned it on the first page but I will again, I had the same problem with the tach cutting out at 5k until I soldered my tach resistor in - but I'm guessing you soldered everything anyways.
I still havent had time to fix my Tach issue, I will be soldering the connection when I have a chance.
- babyblueMX3
