ok now i have a question.
I know that the auto tps is variable, anyone know how i would hook up the 4th wire to the safc2 so it would read variable?
Which injectors for turbo 4 cylinder? (look inside)
- Josh
im running 310cc injectors @ 15psi, and im not maxing them out yet. close but not quite there.
the 1.8 injectors (220cc) i couldent run over 4500 RPM, at full fuel pressure at 7 to 8 psi, it would lean way out.
forcedairram
ok
what turbo are you running because the 16G flows alot more cfm than the vj-14s and vj-11s, fuel injector size depends alot on the turbo. like i said im maxing out 440s at 10psi
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
