The MS8, AKA J-Spec MX6, used the KLZE engine therefore it can't have any EGR equipment because that's what the earlier posts said.
quote from Nd4SpdSe:
My engine does not have the holes required to connect any of the EGR system.
I don't know if they do today or not, but Japan did not require EGR systems
OH NO, NO EGR!!
- jschrauwen
Ms-8 has only 165-170hp not same output as a ze... they are 2 different cars and engines.... You always see MS-8 from japan being passed off as ZE but they are not. I'm sure if you check the heads or even the cams something has to be different.jschrauwen wrote:The MS8, AKA J-Spec MX6, used the KLZE engine therefore it can't have any EGR equipment because that's what the earlier posts said.
- jschrauwen
I didn't know that, thanks!!4u2nv wrote:Ms-8 has only 165-170hp not same output as a ze... they are 2 different cars and engines.... You always see MS-8 from japan being passed off as ZE but they are not. I'm sure if you check the heads or even the cams something has to be different.jschrauwen wrote:The MS8, AKA J-Spec MX6, used the KLZE engine therefore it can't have any EGR equipment because that's what the earlier posts said.
