Euro tails fogging
solo_ryder
Post by solo_ryder »
May not work for the chrom ones......cause the stupid chrome stuff tends to peel and bubble when wet. I am not sure what the CF and the black ones are made of though....
I've always wondered that if you have them ventilation if they would not fog up...normally condensation of cause by a difference in temperature. Perfect example is if you have a cold drink in a glass on a hot summer day, the outside of the glass will condense. If you drill holes, not only should would there be airflow to equalise the temperature difference, theoretically preventing it from fogging up, but it will give the trapped moisture to escape instead of condensing on the lense....just my C$0.0248470
exdream_mx3
Post by exdream_mx3 »
I drilled the holes in mine worked for like a month of so but then they fogged up again only 10 x worse!!!! Finally took them off!! Not worth the hassle in my opinion.
solo_ryder
Ya i was thinking that, but if its completly sealed then moisture cant get in.
ninjajim4
Post by ninjajim4 »
exdream_mx3 wrote:I drilled the holes in mine worked for like a month of so but then they fogged up again only 10 x worse!!!! Finally took them off!! Not worth the hassle in my opinion.
good to kno it doesnt work... other ppl have been advising that too. thnx for sharing
exdream_mx3
no problem just wanted to share my lovely experiences with these p.o.s lights!!!!
