Page 2 of 2
Posted: April 3rd, 2005, 12:51 pm
by babyblueMX3
David Witherow wrote:you guys know that you can make these for your self right........you can get any of the parts at any local facca fasteners or brafasco or any place like that.....i did it like a few months ago and with tax and everything it came to 100 bucks canadian.......if i can find the recipts then ill post the exact parts and number that you would need.
yup same here paied 100cad $ but mine were already done
tonguefreek that was on this board had a special company made them for a couple of guys here.
Posted: April 3rd, 2005, 3:42 pm
by David Witherow
yeah its not that hard i can even get the parts for ppl that are near me like DavidOS......
Posted: April 3rd, 2005, 4:08 pm
by mm2587
Are the ones that you have that squeak stainless steel? After expirementing I discovered the reason that they squeak is that oxidation(rust) from the hardware gets inside the rod end, and the ball is then not rolling only on the teflon causing it to squeak. By using stainless hardware there will be no oxidation and therefore no squeaking. A second cause of squeaking is salts (especially road salt) dissolved in water. (rain/snow/ice) The percipitation falls/splashes on the endlinks and when it evaporates leaves behind the salt. This means again the ball is not rolling on its lining. This is a much simpler issue to fix, just spray down the link with some clean water and it should wash away the salt. If this doesn't fully remove the salt, remove the link, and clean the ball with a rag.
As a side note, these can be made for about $35 for two links in mild steel. (I know, I've built them) Stainless costs a crap load more, as does alluminum(sp. real bad).
Posted: April 3rd, 2005, 4:16 pm
by DavidOS
David Witherow wrote:yeah its not that hard i can even get the parts for ppl that are near me like DavidOS......
sweet do it:)
i await your reply
Posted: April 3rd, 2005, 4:23 pm
by babyblueMX3
mm2587 wrote:Are the ones that you have that squeak stainless steel? After expirementing I discovered the reason that they squeak is that oxidation(rust) from the hardware gets inside the rod end, and the ball is then not rolling only on the teflon causing it to squeak. By using stainless hardware there will be no oxidation and therefore no squeaking. A second cause of squeaking is salts (especially road salt) dissolved in water. (rain/snow/ice) The percipitation falls/splashes on the endlinks and when it evaporates leaves behind the salt. This means again the ball is not rolling on its lining. This is a much simpler issue to fix, just spray down the link with some clean water and it should wash away the salt. If this doesn't fully remove the salt, remove the link, and clean the ball with a rag.
I'll try that
Posted: April 3rd, 2005, 4:49 pm
by neutral
DavidOS wrote:...make sure its really BEEEFY looking one...
yah, BEEEEEFEEEEEE!!
****UPDATE****
Posted: April 4th, 2005, 11:20 am
by Spinkx79
****UPDATE****
me:
"I posted a thread on MX-3.com trying to round up 15 people....Hopefully we can make this happen."
him:
"After playing with some numbers, I've concluded that if you can get 5 sets, I can price them at 50USD shipped for one or 96 shipped for front + rear. Its unfortunatly a bit more then my other links, but this is because I can't get my full bulk discount on such a small order. Turn around time *should* be about a week from payment, however I am at the whim of my suppliers. Last time I got my shippment 3 weeks after I ordered it, while the time before that I got my order the next day. Let me know whats up"
So I am going to tell him I have 5 people.
Spinkx79
nopemx3
Neutral
93SOHC
Marlon
Anyone have problems with this?
Anyone else want in?....let me know.
Posted: April 4th, 2005, 11:23 am
by projectmx
i've seen the ones you can make yourself and they weren't lubricated like the ones this thread discribes... so as long as i have my job by sometime next month i'll be in for these soon also.. front and back
Re: ****UPDATE****
Posted: April 4th, 2005, 12:01 pm
by babyblueMX3
Spinkx79 wrote:****UPDATE****
me:
him:
Spinkx79
nopemx3
Neutral
93SOHC
Marlon
did jeff approved this GB ?
Re: ****UPDATE****
Posted: April 4th, 2005, 12:55 pm
by Spinkx79
oops!!!
If Jeff is Custommx3, then yes i have sent a PM
Posted: April 4th, 2005, 1:20 pm
by babyblueMX3
nope Jeff is the owner of this site and barry (custommx3) is a moderator here
Posted: April 4th, 2005, 4:29 pm
by neutral
List looks good from here. Get GB approved and I'm def still in for the front and rear sets.
***UPDATE***
Posted: April 4th, 2005, 5:29 pm
by Spinkx79
OK, providing Jeff gives us the ok.
$98US will cover all four links shipped
He will need 50% down.
And here is his reply to some of yours:
"You can make these yourself, however It is impossible (asfaik) to make these own at a cost cheaper then mine. I glanced at the mx-3 site, and people said they were making them for 100cad. My links work out to be about 119cad. And your getting all stainless hardware. Its the stainless hardware that forces me to drive up my price. Also some bad news, price shipped on 2 sets would have to be $98Usd. From here, you would need to get at least a %50 deposit on the links. Once I recieve that I can order all the neccaassary parts and the links should ship in about 10 days, but as mentioned that depends solely on how fast my supplier deleivers. As for adjusting I can get them close, then you guys can compare them to the stock links and finalize the adjustments once you have them."
So its up to you, you can take a stab at fabing up your own or jump on this deal. I dont have the time to run around right now. And plus by the time you run around here and there you would prob burn up the extra $20 your spending anyway.
Again if anyone has one lying around, could you measure it and let me know. IIRC, i got roughly 2" for the front and 3 1/8" on the rear (Center of bolt to center of bolt).
