I had an ABS sensor problem and did a bit of troubleshooting. I got a used one with the same reading as your post 1.3K Ohm's and it worked fine.Macen wrote:The one I have measured 1.3kOhm, and the limit is between 1.6-2.0kOhm.
Need help finding a rear ABS sensor
- FlyVFR
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
Yes my ABS light turned off and the system works well.
Compare the reading with another sensor, if they are close in value, then I would troubleshoot the circuit further. I'm assuming you cleared the memory (step on the brakes 10 times quickly while in diag mode)
G/L
G/L
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
