got my block from the shop today
- babyblueMX3
yeah stock sleeves.
Matt Maas is currently running over 20+ pounds off boost and making 475whp on his KL
RIP 400whp ZE-T MX-3
- babyblueMX3
hey guys..just got my heads too..
got czt retainers and locks in there
interprep springs, stock klze valve, and duratec (hat style) valve seals
the heads was decked, valve seat were done and the heads were cleaned in and out
their are on the engine right now...smells turbo
so when you lettin me in on the bank jobs you are doin to pay for all this?:P
Re: got my block from the shop today
i don't really know what any of that means, but it all sounds so expensivebabyblueMX3 wrote: Aluminum block bored 0.020" over
8.7 CR Wiseco 4340 forged pistons
Wiseco plasmamoly rings
Wiseco floating wrist pins
Wiseco Spiral-lox
Scat forged I-beam rods (magnaflux and shotpeened)
ARP rod bolts
Polished and balanced forged crankshaft
Clevite 0.060 302 undersized rod bearings
Toga High-performance main bearings
Entire assembly balanced
well, that, and very very fast
1992 GS/RS Mutant Automatic
- Zoso124
How much did you shave the heads? I took roughly .025 off of mine and the timing was screwed, the timing belt jumped after 4k. I had to resleeve idler pulley No. 2 2mm's to take the slack out of the belt in a certain position. Now I think the belt is too tight. This was all done on a set of DE heads, the ZE heads are actually higher compression, most people would say I'm nuts but I've seen enough of them and it clear to see the deck is thicker on the DE heads.
Mike Evans
Gone:
Gone:
- babyblueMX3
not sure about the decking..I'll ask tomorrow. They were almost perfect when I gave them my heads..They should not have taken much off of itZoso124 wrote:How much did you shave the heads? I took roughly .025 off of mine and the timing was screwed, the timing belt jumped after 4k. I had to resleeve idler pulley No. 2 2mm's to take the slack out of the belt in a certain position. Now I think the belt is too tight. This was all done on a set of DE heads, the ZE heads are actually higher compression, most people would say I'm nuts but I've seen enough of them and it clear to see the deck is thicker on the DE heads.
