The solid blue wire will only show 12v when in AM/FM source mode. This means your amp will be off while playing CDs. The blue/white wire shows 12v as long as the deck is powered on regaurdless of the source mode.manowar821 wrote:Don't you use the blue power antenna wire as the remote on/off for the amp??
Some manufacturers do deviate from these standards and make the blue wire behave like a blue/white wire. But just to be safe, use that blue/white for your remote amp turn on.
Good luck CarMan, post any questions you have along the way!
