Kinda old vids of my car i never put up. (vid)
- papa roached
wow, sounds teh win!
- XxantwawnxX
I think its just you, but then again im not sure what ur saying.
- XxantwawnxX
thought i was..but even so this vid is really old when my motor was runnign fine. Besides turns out my head gaskets are fine...eh..or at least ok : P.
hmm as soon as i hit the gas it goes...guess u cant really tell when my foot goes down since u cant see it.
- Mazdaspeed96743
- XxantwawnxX
Yea i love the sound, although its not for people who cant take loud sounds..or dont like loud noise while driveing. Im use to it, i had th esame set up on my black mx3 ..cept that one was completly gutted and it was even worse inside.
hello soundproofing...XxantwawnxX wrote:Yea i love the sound, although its not for people who cant take loud sounds..or dont like loud noise while driveing. Im use to it, i had th esame set up on my black mx3 ..cept that one was completly gutted and it was even worse inside.
1992 GS/RS Mutant Automatic
