How to remove gauges and gauge dash trim
DJester187
Re: How to remove gauges and gauge dash trim
Post by DJester187 »
hey mike, it was kind of a point and click if you will, the cluster of wires that goes into the steering collum i would hook up a voltage meter to a wire with no signal, then click on the parking lights, once i found on that shot a signal after that i spliced and have been up and running ever since. hope that helps. if not i'll try and see what color the wire is later and let you know.
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
