Re: Headlight Dirty Inside
Posted: September 20th, 2003, 7:47 am
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by JDM:
If your lights dusty/fogged up from the inside you could do two things to clear them up.<p>1. Take your lights apart and clean them. To take them apart you need to bake/heat them up in the oven over 10 min period. Preheated oven to 225F. Turn oven off when lights are inside. Use cookie sheet. You will need to use Black RTV sealer to put them back together. Make sure no leaks (air test, plug vents)<p>
2. Use distilled water and gentle soap and try cleaning them without taking them apart. Rinse. Air dry.<hr></blockquote><p>
he he he for some reason i have an idea that someones gonna try to put them in the dishwasher<p>[ September 20, 2003: Message edited by: Mnemonic ]</p>
