Lets see some ENGINE BAYS ~!!
- papa roached
Re: Lets see some ENGINE BAYS ~!!
thats a KL-DE, at leas the manifold is, technically is is a straight neck but not a KL-ZE straight neck
- papa roached
<img src="http://www.imagestation.com/picture/sra ... d97e48.jpg" alt=" - " />
this is the straight neck
<small>[ October 01, 2004, 01:18 AM: Message edited by: papa roached ]</small>
MikeUK
None of these are mine, but are all fine examples of KLZE. Hats off to the people that did them.
<img src="http://memimage.cardomain.net/member_im ... 173_37.jpg" alt=" - " />
<img src="http://memimage.cardomain.net/member_im ... 8_full.jpg" alt=" - " />
<img src="http://memimage.cardomain.net/member_im ... 9_full.jpg" alt=" - " />
Tyler17rose
Those last 2 bays are probes. Still nice bays though
Mods:
- JWMX3
yes you are blind, you had to click on cosmo959's link to see them.Am I blind? I don't see a straight neck KLZE and I would certainly know one when I see one.
But paparoached aint blind :p
by the way MikeUK.... that last one in the probe is a work of art
- papa roached
yea it is but i dont think the probe ones are KL-ZEs, why didnt they use the straight neck manifold?
- JWMX3
thats right... those 2 are definetly DE's.... thats ok, De's are welcome
(Im doing the klde swap this winter along wiith 5 speed swap)
thats partially why i made this post im starting to buy parts and gettin excited about it
Ahh ok the links...Didn't check them out..why do people still use links when you can put the picture directly in the thread using imageshack.us???
My Cardomain site
My Cardomain site
For free, might I add.
My Cardomain site
My Cardomain site
the only bad part about the straight neck is you have to move the battery and if you dont have an emergency cut off switch, they wont let you race...at least not here.
- papa roached
well, when ya do it you should get ya a curved neck manifold, almost like putting a KL-ZE intake on a KL-DE they get a few ponies from itOriginally posted by JWMX3:
(Im doing the klde swap this winter along wiith 5 speed swap)thats partially why i made this post im starting to buy parts and gettin excited about it
Mradio
I don't think you can put a straight neck ZE into an MX-3, it will hit the brake master cylinder. You have to use curved neck manifold, but you could put a regular DE manifold in the mx-3.Originally posted by ZEmadman:
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
- papa roached
see cosmos car or my above post, thats a straight neck in a MX-3
yeah, i think vlad's pic is the A-spec(de?), and cosmo is the jspec(ze).
roached has the one best suited for us, the ms8 (millenia a-spec?) one.
- papa roached
actually it was a straight neck motor that i put the intake and tb off a millenia on, i wanted to make sure i got the 10:1 compression and KL31 cams
