new solid end links
projectmx
Re: new solid end links
i didn't see an actual price posted how much are they? do you know if they will fit a 95 protege also? they look very similar
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- babyblueMX3
that was the first postthey can be seen on here
cost was 65$ for all 4 if anyone wants them just drop me a line
RIP 400whp ZE-T MX-3
projectmx
not sure how in the world i missed that i flipped through the thread like three times real quick and missed it. sorry about that. but what about the first ? about them fitting a protege... any idea if they will? i need them for my gf's second gen also
ProjectMx
Cardomain
Cardomain
I occasionally have a very slight clunking when driving on uneven roads or when the front wheel in on of the sides "drop" into a pothole....
I dont think its my springs bacause if i drive fast while going over hills and such where they really get compressed theres no sound at all
Could this be the endlinks clunking???
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
- babyblueMX3
yup classic case..that's what ring the bell for me to check them...3 out of 4 were broke
Babyblue:So i just guesstimate that theyre the ones doing the clunking and replace them?? Or can i actually see pfysically on them that theyre broke?
I have been under the car before while having this problem,but the little rod between the two nuts werent broke/rusted over...
- babyblueMX3
when i saw that mine were broke..the link it self wasn't broke but the bushing were (where the links connect to the tab) there was one missing too don't know how that happened though
Babyblue: Okay so if i get under the car again and take a closer look at those endlinks,and they "appear" to be fine then theyre not the cause for the clunking?
- babyblueMX3
if they appear to be fix and solid then your problem will be something else
Okay thanks babyblue,so are theese "solid" endlinks better/cheaper than original mazdaparts as it is with most other aftermarket parts?
And will i need to do lots of mods to the car to get theese endlinks to fit probertly?
Mainly my concern is if i can go back to original parts lateron,or is that not possible after having tryed theese on??
- babyblueMX3
no modification what so ever to fits these..you can install back your oem if you want to...Biggest reason why I bought those was because they are indeed cheaper than oem..
if you want some contact tonguefreek on this board
Yeah i thought so,damn OEM prices
- babyblueMX3
I can't actually see the difference because i went from didn't have any to those so I can't comapre with the stock ones
perhapsadingo8yerbaby
Agreed it does sound typical like could be the endlinks. A leaking strut cartridge seal can also cause the sound you describe. Easy enough to check too. Just do a visual inspection of the corner where the sound is coming from. Look for any sign of fluid on the outside of the strut. They should appear dry...Originally posted by Dennis Jørgensen:
Thanks for the advice perhaps,but the struts are quite new and all dry
Man i hope that its just those stupid endlinks,and not something else thats hard to locate or replace...
