<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BATTOSAI:
Jeff, what kind of solenoid are you using? I planned on using the Fpr one, as I won´t use it anymore, but if I can found anything with larger ports I´ll go for it!<hr></blockquote><p>I have a bunch of extra solenoids I have scored over the years. They are all just like the FPR solenoid, for the most part.
Believe it or not, I still have the factory FPR arrangement in place. I figure, the closer to stock the ECU thinks it is, the fewer troubles I'll have.
You won't need larger ports - you are only activating the wastegate actuator.
Vris Mod under boost
Re: Vris Mod under boost
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mrspanky79:
hey jeff are you still using the Simple Digital Systems?<hr></blockquote><p>Yep. Works great.
I use a Cartech FMU to push up the pressure across all of the injectors and the SDS-EIC to add the remaining fuel.
The FMU means I'm not relying on the SDS for all of the fuel in boost.
