opinions on best clutch kit for ...
- cjthor
Re: opinions on best clutch kit for ...
Well it looks like I am gonna get the ACT setup that ashley is looking at as well. Its getting put in tomorrow so I will keep you all posted.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
JWMotorsports
I think you'll be VERY please with the results!!! Just remember that the 300-500mile BREAKING IN period will have a HUGE affect on how your clutch performs and lasts. If you don't break it in and start getting on the car hard or doing high RMP gear changes during the break in period, it could very likly cause it to slip. Once it starts slipping you start scaring the flywheel and the clutch looses it's tenatiouse gripping power!<p>- It is WORTH the break in period of 300-500miles of stop-n-go traffic!!!!!
Has anyone used any of the unorthodox racing clutches? They also have a lightened flywheel. I was just wondering peoples opinions of these clutches. Apparently they just started making sprung hub clutches, so I guess people might not have used there previous unsprung units for fear of destoying there transmission. They use kevlar clutches for 2WD cars, and have several stages. Incase anyone is wondering there website is
unorthodox racing
unorthodox racing
- cjthor
So should I run as little boost as possible for those first 3-5 hundred?
Jarid Perry
JWMotorsports
I'd say your probably better off runing the stock wastgate setting. It would be easier on the clutch, esecially in an emergancy situation if you had to punch it to avoid an accident!
