Yeah, what he said!
how to get power supply to indiglo gauges
Re: how to get power supply to indiglo gauges
Hank
'92 MX-3 ZE *SOLD*
'05 RX-8 Touring
--All those who wander are not lost-- JRR Tolkien
'92 MX-3 ZE *SOLD*
'05 RX-8 Touring
the dimmer wire i'm talking about is the constant power wire for the dimmer switch lightbulb.
It isn't the variable voltage wire that tells how bright/dim the bulbs in the dash should be, that wire is a different color (red/gray i believe).
DONATE TO MX-3.COM
DONATE TO MX-3.COM
I know gro..But it was because people was talking about ruining their indiglos when hooking them into their dimmer,so i just explained why some have experienced that and posted a solution
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
mine is hooked up to the dimmer wire (constant power of course).
Those who have wrecked them I`d bet hooked them up to the dimmer variable power wire.
nope-mx3
nope-mx3
- mitmaks
i just hooked up mine to battery and put in switch that i can turn them on/off and fuse wouldnt be too bad in case of short
I'm about to wire mine in and before I do that I just wanted to clarify a few things. I've decided to use the wires behind the dimmer switch since this seems to be the easiest to get access to. Now, heind the dimmer are 3 wires:
1) Red w/ black stripe
2) Solid Red
3) Solid Black
What I want to know is, which wire between #1 and #2 is the constant 12V line and which is the variable? As I understand it, I should be tapping into the constant 12V line, correct?
For the ground, am I able to use splice into the black wire on the dimmer or should I just find a metal bracket underneath to solder the ground onto??
As a side question that's slightly related, I'm also thinking about putting in some lights to my heater vents and was wondering as far as getting power to them goes, is it safe to assume that any wire that matches whatever the 12V constant wire I'm looking for behind the dimmer will also be the same 12V wire as well?? For example, if the red w/ black stripe wire behind the dimmer is the 12V constant, will the red w/ black stripe wire behind the hazzard switch also be a 12V constant since they look the same??
2) Solid Red
3) Solid Black
1) = Constant 12V1) Red w/ black stripe
2) Solid Red
3) Solid Black
2) = Variable (about 2 - 10V)
3) = Ground
The RED / BLK wire should be the same anywhere you find it. Before hooking up your vent lights, just stick a test light on it to make sure.
