If that's the original engine it isn't a K8. If it's not the original, who knows how many miles it ran before it was fitted in that Probe.... also i will compression test it again cause my theory with that is that maybe it sat so long that the rings shrunk up and just will not reseat and that is why i do not have the right amount of compression. it is only supposed to have 35 thousand miles on it so the motor should still be good [/QB]
Rings shrunk up? No way, José.
