ZE Distributor with internal coil???
Re: ZE Distributor with internal coil???
mine looks the same as well............ so for those who've had the motor come in with the internal coil disty.. were you able to use it or did you still have to swap it out?
The distributor on mine did not work. I didn't bother to check if it was a wiring issue or the dist. was just dead. It was easier just to put my almost new K8 one on there.
91 Eagle Talon Tsi AWD *RIP*
