Its all in what you wanna pay I guess or what you like. I just decided when I got it to get the best clutch I could get. So it might be a bit much, at least I know it wont slip. :p
<small>[ February 09, 2004, 10:09 PM: Message edited by: papa roached ]</small>
Exedy Clutchs....??
- papa roached
Re: Exedy Clutchs....??
That combo should work fine. The stock MX-3 flywheel is lighter than the stock MX-6 flywheel, so just make sure that your aluminum flywheel is really an improvement over stock. (Probably is...)Quick question im doing a ZE swap so would the MX-3 V6 5sp fit on there? if so could i use a Mx-6 Aluminum Flywheel with an MX-6 Clutch? Need to know before i blow any money.
1992 MX-3 kl-ze, atx-to-mtx conv.
1993 MX-3 RS atx
1993 MX-3 RS atx
heeeellooo??!?! do u not see that the exedy is made for the klde which has only slightly less torque than a ze??Originally posted by papa roached:
yea, but how bout a K8 vs a KL-ZE? i would rather spend the extra cash and be sure my clutch can take it
i know my exedy will not slip cuz a ze only has more hp than a de and maybe slightly more torque. spend your money as you will, its your money. im just trying to let people know if it wont slip, it wont slip anything more is unnecessary like my fuel pump example above. having a hard grabbing clutch will not make your car faster. its meant for cars that have insane power that anything less will slip. you will never make that much power period. unless your going to dump 3x your cars value or more into a turbo system and a fully built engine. you're using clutches that super boost junkies use on pt cant even make slip, they make tons more power than a measily na not to mention tons more torque. u wasted your money but at least you like it, thats all that mattters huh? it is your car anyway.Originally posted by papa roached:
![Driver :driver:](./images/smilies/driver.gif)
- papa roached
and the fact that i have been looking into superchargeing it means i wasted my money on a good clutch that can take that kinda power, or how about adding N2O on the car?
i agree with steeb, thats why i'm happy with my excedy clutch myself, haven't had any problems ![Throw Up :throwup:](./images/smilies/throwup.gif)
92 323 KF-ZE V6 swap done by me 2 1/4 header back exhaust no cat car now for sale for very cheap! email me at queensnysfinnest@aol.com for pics and questions
I have a ZE and my Exedy works really fine... never had any problem in hard launches or anything..Originally posted by UrBaNsTyLe55:
i agree with steeb, thats why i'm happy with my excedy clutch myself, haven't had any problems![]()
-italian lonely MX'er-
