MSD Igntion gains on N/A?
Re: MSD Igntion gains on N/A?
an ingition module will greatly improve throttle response, and maybe increase power by 1-2 on a dyno, which is negligible. They only increase power on turbo cars and highly tuned NA cars. I think some probe guys saw a 4whp gain with one installed on their KLZE powered cars, but on a K8 i wouldn't expect much.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
im gettin ready to receive a Mallory ignition from Corksport. how do those rate to you all. they said that it was better than MSD, also the Mallory ignition im gettin is digital...
let me know
Justin
let me know
Justin
93' Mx-3 GS, repainted laguna blue with pearl, 18 inch wheels (white) with Falcon ZE512 ruppers, custom headers with 2 1/4 inch exhaust, ported TB and intake manifold, ACT clutch, and ground-control coil-overs.
- babyblueMX3
well IF you have a 7 plug then yes on number seven (wich will be written C for coil) those disty only came on klze's and on kfze's. If you don't have it you have to add a tower to your stock disty
RIP 400whp ZE-T MX-3
- babyblueMX3
- babyblueMX3
PRD is the brand
and IIRC is short for If I Remember Correctly
- babyblueMX3
yes you can..actually 99% of people here uses it with the msd 6a
- vozaday2000
you have to build one yourself.
here is a manual by Gro
http://www.projectmazda.com/howto/hei/index.htm
its in the v6 faq
its in the v6 faq
- vozaday2000
i don't know where to get one and i may get shot down for suggesting this but you could probably break off the top of a sparkplug (its not hard, really, and it works good for cracking windows ) so you have the nipple and the porcline (white stuff, i think that is what it is called) and then attach it from there. it might look ugly but it should work. just a suggestion
