KLZE in a ford Escort
Re: KLZE in a ford Escort
i believe you need all 4 v6 mounts but i remember dave saying something about the g5 transmission(mx3) being the same as the g15 transmission(escort), those prices suck though i think you can get the set for like $260 from corksport.com
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
David Coleman
I know that both lower mounts are different, and I've seen the entire mount and mount bracket for the passenger's side mount swapped on every KL-BG chassis car that I know of. You might be able to use your upper tranny mount again, but I don't know for sure. <P>You do have a MX-3 V6 cross member, right?
David Coleman
pelado
You can buy all 4 Mazdaspeed mounts cheaper than you can get the 4 stock mounts from a Mazda/Ford dealer.
Good luck w/ the Escort ZE, you will surprise many people out there.
ProtegeSTS
if you can find him, talk to Darrin on the Escort boards. He had a Mercury Tracer with the ZE like 2 years ago. He has since sold the car IIRC. <P>And you cant use the VAF off the escort. Its a different type of VAF than what the k series takes.<P>And to Hy300, the escort has MORE room under the hood than a MX-3. Same chassis with no low profile hood.
-93 MR2
#129 E-stock
#129 E-stock
I have a VAF from a KL-03 laying around the garage. Came out of a '93 Ford Probe w/ ~50k miles. Shoot me an e-mail if you're interested: ogimoj@yahoo.com
