My KL-ZE dyno run
Re: My KL-ZE dyno run
RE: fuel and performance, i used to have a bracket 1 drag car ran in 10's (muscle car) and would use airplane fuel high high octane, dad would get it for me, car loved it. Like to get some now, for my gs i run only synthetic oil in gs have nice day!!
What is your timing set at? You will lose<BR>Hp if it's retarded. Those engines only have<BR>10:1 compression, right? Premium 93 should<BR>be good for up to about 11.5:1 compression.<BR>But that depends on your timing advance. If<BR>it's not too expensive, run your car on the <BR>dyno again and play with the timing. Keep<BR>advancing it until it spark knocks... it will<BR>be totally obvious by the Hp numbers when it<BR>is knocking. Then back it off about 2 degrees.<P> ![Very Happy :D](./images/smilies/icon_biggrin.gif)
-Brock-
