that would be incorect. inverting a sub in a ported boc lowers the tuning frequency. doesn't boost anything. it basicly makes the box bigger. also there aren't many dail drivers with 160db. a 148 is a good respectable score and is very possible. its mostly in the box. i have seen 2 12" shocker extreme 3s hit 153db with a 20w road gear amp. that should tell you that box design is everything. i plan to build a box for 2 6.5" kickers that will prob blow everyone in my town away other than my curent setup. i have doen much research on boxes latly and there are ways to make subs louder simply by the way the box is designed. such as a folded horn, snailshell, or transmission line box.--------------------------------------------------------------------------------
Originally posted by BADMX3:
(but my subs are inverted which i personally think makes a lot of difference.)
No it doesn't. If it's ported it should actually help by increasing the box size for more boost near the tuning frequency.
148db's with only one sub !!
Re: 148db's with only one sub !!
lakersfan1
So increasing box size doesn't increase efficiency? Sounds like you need to get some more practice working a box modeling program.Originally posted by mzdspd:
in one sense you are correct. bigger boxes are normally more eficiant but if u take a box that is designed to have the subs mounted normal and then invert the subs the tuning is now off anc can make a big difference in the output. depending on the sub it could increase or decrease
custommx3gtx
i believe it my friend hit 153.2 with a single 15" dd sub in a 8.5 cubic' box in a golf with 1000 watts rms memphis amp i hit 159.1 in my mx-3 with 2 15" 9515s dd subs in a 9 cubic foot box for each sub in a wall 4 bd 1500 amps 2 battries
BumpNGlow
you and your friends have great tastes in subsOriginally posted by custommx3gtx:
FOR SALE, AS A PARTS CAR
quicksliver
I don't get the whole SPL contest thing. Iv'e got a 4ch JBL px300.4 amp putting out 75w rms to each of my Infinity Kappa speakers and a JBL bp600.1 amp powering my two 12" Rockford fosgate dvc subs /w a 1F cap...and when i crank the volume even just a bit it gets CRAZY loud. I have low tone hummm in my ears for a good 20-30min after i turn off the stereo...and i don't the amps arn't even turned up! Blows me away how you guys can argue over ~10dB range with all these different setups.
p.s. Yes i know...i have to update my sound domain page.
<small>[ November 14, 2003, 04:30 PM: Message edited by: Quick Sliver ]</small>
lakersfan1
dB contests are fun, but are crazy for daily listening. I did an SPL set-up for a kid with dual bp1200.1's and dual 15" JBL GTi's and it got so damned loud on our first test drive, that if felt like it was crushing my larynx and I had trouble breathing. And that was with the "SQ" port.
But I do like my sub system to at least have the dynamic room to hit 140's.
