Page 2 of 2
Re: Mounting rear speakers... what was Mazda thinking?
Posted: July 23rd, 2002, 9:39 pm
by Sparky75
Over here in UK there is a adaptor plate available that mounts onto the rear pods and allows the fitment of standard type speakers
Posted: July 24th, 2002, 7:49 pm
by Bundy
I believe 6 1/2 will fit in the rear easily without much modifications. I got sony explod speakers which had tons of holes around speakers. It took more time to install front speakers since I chose 6 1/2. It was tight, but fit right. I believe mazda recommends 5 1/4 for front and rear, but 6 1/2 fits just fine.<P>Bungo
Posted: July 26th, 2002, 9:28 am
by SYE WELCH
Hi all <BR>I managed to squeeze 6x9's into the standard rear speaker position, but I did have to make pods for them out of glassfibre and It was a couple of days work. But it sounds better than 6 inchers. About subs I would recommend 2 12" HFC rockford fosgates in a sealed box, I had them in a ported box but found there was too much air floating about in the boot/trunk and the bass was not tight enough. Both subs are running from a Alpine MRP-F320 amp. Also if you can't afford expensive sound deadening you can use the stuff you use to seal joins in the roof of your house although you'd need 2 or 3 layers it will save you loads of cash.
Posted: July 29th, 2002, 2:19 am
by Casino
i had no trouble replacing my rear speakers at all. i put in 6" audio bahn speakers with a lithium base or somethin i forget exactly what it is. anyway they fit nice and easy and sound great to maybe i got lucky ? or maybe 6s fight easier.
Posted: July 30th, 2002, 11:44 pm
by Sparky75
Hiya, as i decided to change my rear speakers now, i got a set of adaptor plates for the rear pods, they cost me £10 UK pounds. a company called Autoleads sell them here and they also come with the wiring from the mazda plug to universal speaker connectors.<BR>they must be available in the US i would have thought. <A HREF="
http://www.autoleads.co.uk" TARGET=_blank>www.autoleads.co.uk</A> is the site for where i got mine.
