Page 2 of 2
Re: need a list of all swaps
Posted: June 10th, 2003, 10:15 am
by David Witherow
no im using the '98 protege motor with an 1.6 SOHC mx-3 ecu
Posted: June 10th, 2003, 12:11 pm
by Marlon
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by David Witherow:
hey if you want i can meet up with you and show you if you want im only 45min away???<hr></blockquote><p>u should come up to the big mx-3 meet on june 21
Posted: June 10th, 2003, 4:33 pm
by ltjrunner
marlen, im assumming ur still running a 94 pro lx engine with a mx-3 ecu. i have the 92 mx-3 which we all know is a 1.6 sohc...and if hes running the mx-3 ecu, it would be easily adpated for the safc..now what about the reprogramming. last i heard corksport was working on it but nothing complete as of last i heard. so where are thei getting the ecu re programmed???
Posted: June 10th, 2003, 4:49 pm
by ltjrunner
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr> marlen, im assumming ur still running a 94 pro lx engine with a mx-3 ecu. i have the 92 mx-3 which we all know is a 1.6 sohc...and if hes running the mx-3 ecu, it would be easily adpated for the safc..now what about the reprogramming. last i heard corksport was working on it but nothing complete as of last i heard. so where are thei getting the ecu re programmed??? <hr></blockquote><p>to make more sense-if marlon is running the 94 pro lx engine with the sohc ecu out of a mx-3 is it reprogrammed or no marlon? if not, well the piggy backing the mx-3 ecu would be a good possible solution and just swap engines...correct me if im wrong on this. thanx<p>about the reprogrammed ecu, where are you getting these from? last i heard corksport had nothig avaiable, im checking right now and im still not seeing anything. so where are these reprogrammed ecu;s commng from?
Posted: June 10th, 2003, 5:06 pm
by Marlon
i running a j-spec 94 bp with escort gt wirring harness and ecu
u can use the sohc wirring harness and ecu but u might run lean, u don't get virs and u don't get the 7300 rpm redline
so whats the point of the engine swap
<p>so just use the escort gt (or pro lx in the us) wirring harness and ecu
i got both for less then 250 cnd <p>and about the safc u need a 4 wire tps and these engines only use a 3 wire unless u use the auto tps
i have heard u cause use a map sensor but don't know how
Posted: June 10th, 2003, 8:35 pm
by ltjrunner
aight kool. cept still on the hunt for a gtx ecu and wiring harness. im hoping my uncle can find one for me. thank you us army for putting him there!! id really like that way cuz then i dont have to bother with a safc. <p>the 7300 rpm redline
is very nice. well.......geesh i wish college wasnt in the damn way of this, but it is so time will tell when i can get this done. thanx for ur help marlon
