Page 2 of 2
Re: New Intake causes car to die...
Posted: February 22nd, 2003, 2:21 am
by marshmallow15
you're welcome.
Posted: February 22nd, 2003, 1:22 pm
by RanMan
Ok, does it matter if the hose is piped in before or after the MAF? I am assuming it needs to be after, but I thought that the hose was before on the stock intake box.<p>[ February 22, 2003: Message edited by: RanMan ]</p>
Posted: February 22nd, 2003, 10:45 pm
by azmtbkr81
Marshmellow-
Thanks a bunch, sorry I didn't say so earlier. <p>RanMan-
It has to be after the MAF, it is a different hose than the one that plugs into your airbox. It is a fat hose that plugs into the side of the intake and is attached to a little resonationg box pretty close to the AICV. It is a fat hose that plugs into the side of the intake and is attached to a little resonationg box pretty close to the AICV. If the air going in has not been metered it throws off the computer and causes your car to die. <p>Now that the new intake is on I am having the infamous idle that goes from 1000-1500 rpm and back down. I will probably read through old posts to try and find out how to fix it but if you guys have any ideas that would be great!<p>Also, tommorow I will get some pictures and post a how-to so that you can all get an intake!
Posted: February 22nd, 2003, 11:56 pm
by mx3man83
I have found that with the RS the filter has to be butted right against the maf. I tried running mine at the bottom of the car but the car wouldnt even start.
