Escort GT motor
Marlon
Re: Escort GT motor
Post by Marlon »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by cre8v mx3:
any problem with clutch not fully engaging?<hr></blockquote>
it's weird how u had to shave your slave cylinder(i think thats what it was) cause i talked to derrick at corksport and he said hes never had that problem and tubroge said the same thing
i hope i don't have to
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
JWMotorsports
Re: Escort GT motor
Post by JWMotorsports »
No you don't have to shave the slave cylinder release rod. I have the MX-3 slave on my Pro-LX drive train. If anything the release rod needs to be lengthened because it just BARELY releases. I'm swapping in the Pro-LX slave to see if there is any difference, but when I got the slave it didn't come with the release rod so I haven't tried it yet. Still using the MX-3's for now.
OsoSlo z28
Re: Escort GT motor
Post by OsoSlo z28 »
i had to shorten my slave cyl. rod about a 1/4in. because the clutch would not fully engage. it was like it was bottoming out keeping pressure on the clutch fork. what i'm starting to wonder is if it's possible the mx3 and the 93 protege lx cluth forks have a different angle to them. also not sure if it had something to do with the pressure plate. for those of you using the ACT clutch kit, is it for the protege? mine is for the mx6 which holds more tq but is supposed to fit the same. not sure. i still have my old slave cyl rod from the mx3(same size as the protege) so when it's time to replace the clutch, i'm going to look more into it.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Machelski65
Re: Escort GT motor
Post by Machelski65 »
Hey guys I put the BP 1.8 DOHC in mine late last summer. As far as performance boost, can't compare, because my 1.6 engine was blown when I bought it. The performance is great, 1st thru 2nd rubber, and smooth and quick to over 100mph! As for easiness to install. It was as easy as putting in another 1.6! I used my mx-3 tranny, and just had to use the mx-3 flywheel and clutch. Later A.J.
Marlon
Re: Escort GT motor
Post by Marlon »
i had to shorten my slave cyl. rod about a 1/4in. because the clutch would not fully engage. it was like it was bottoming out keeping pressure on the clutch fork. what i'm starting to wonder is if it's possible the mx3 and the 93 protege lx cluth forks have a different angle to them. also not sure if it had something to do with the pressure plate. for those of you using the ACT clutch kit, is it for the protege? mine is for the mx6 which holds more tq but is supposed to fit the same. not sure. i still have my old slave cyl rod from the mx3(same size as the protege) so when it's time to replace the clutch, i'm going to look more into it.<hr></blockquote><p>ya i'm putting it the mx-6 clutch too but derrik at corksport said it should be fine
2004 RX-8 - Project
torpedan
Re: Escort GT motor
Post by torpedan »
the pictures didnt focus wvery well most are blurry but the clutch forks are both very diffrent and are not the same angels
-torp.
I don't own a Mazda.
