Re: Marc's S2- Autozam AZ-3 B5ZE -BOOOOOSSST videooooooo
Posted: July 24th, 2014, 12:07 pm
5.5 PSI so very little! Can't imagine the rx-7 injectors are under much strain!
Upgraded to a proper variable TPS using an automatic BP throttle body. This gives far more linear response and accuracy for megasquirt
And a cheap unused K&N for Mr snail:
I rebuilt a rear caliper, it was quite a chore cleaning it up! It was starting to wear grooves in my discs so was due new seals etc.
Also changed the cam cover gasket as the generic brand one failed after about 9 months use. Mazda OEM FTW!
Still looking clean under there:
Been working on this for a few days, only passenger side done:
Rx-7 FD seat in an Mx-3, horrible task as the mx3 rails are at different heights, spacings, angles etc! Took many many hours of drilling, grinding and welding. Need to find a cheap driver side now
Super comfortable, love these seats!
