wont go on!
Other - General Mazda Discussions
bigluke
wont go on!
Post by bigluke »
when i bought my mx3 the front left tire was on but one of the lugs was not on. The lady said that she dint know but that there was some more lugs in the side pocket, so i dint think much of it. I came home and ive been trying to put it on ever since i think the part the lug goes on is stripped or broken :( what do i do? how would i fix that? what would i have to replace, and how much? Then again im thinking i could strip the inside of one of the lugs put a drop of glue on it and leave it, no one will know the difference and when i need to get it off ill just take it to a show and the force of the air-impact should rip the glue(i hope) what do u think?
Dont let anyone tell u u cant run subs off of your head unit,(temporarily that is) all u need is a big box :) <p>-Luke
Tyler17rose
Re: wont go on!
Post by Tyler17rose »
All i can say is get it fixed properly and dont glue on a lug nut! You dont want your wheel flying off on the highway. Its a long shot but its still better to get it fixed!
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
mx3man83
Re: wont go on!
Post by mx3man83 »
Cars drive all of the time with 3 lugnuts. Doesnt mean i recommend it, but it happens. Take it to a machine shop and have them clean the threads on the stud, or if they are REALLY bad, have them rethread it.
My Cardomain site
Guest
Re: wont go on!
Post by Guest »
get a tap and die set and rethread it.
bigluke
Re: wont go on!
Post by bigluke »
how much would that cost?
quinn_seipp
Re: wont go on!
Post by quinn_seipp »
prices drastically vary with machine shops. There is one in my town that does work that is "good enough" and charge very little. Then there is one that does work that is amazing :eek: but they also charge an arm and a leg, lol.
130 hp and 1000 horsepower strong, ;)
Guest
Re: wont go on!
Post by Guest »
Mananamx3er Knows His stuff :cool:
David Witherow
Re: wont go on!
Post by David Witherow »
you guys are kidding me.....just take it to a shop and have them fix.....thats the only way to do it right.....i had that happen and it was a very minimal cost to have this fixed.....i think like $50 bux....maybe less.....
Return to “General Mazda”
