My '94 MX-3 squeakes when i first start it but then its fine after that. Then about 5 mins after its running it starts to die almost, then i give it gas and it goes back down to dieing, maybe thats my battery so i charged it and then it was running fine so idk if i have a weak battery or an alternator. Also my car doesnt seem to heat up fast its on the very bottom past cold and i have to rev the engine high for a while to warm it up its real wierd. My accelerator is really touchy, i pretty much just put a toe on it and the thing high revs, is there some way i can fix this without too much trouble? Well if ne one could really help me on this id really really appreciate it.
Thanks,
Jon
a few technical problems with my car can anyone help?
Re: a few technical problems with my car can anyone help?
You can adjust the throttle cable at the throttle body!! Use the 2 nuts at the bracket holding the cable to the intake manifold!! It works like a bicycle brake lever...in for loser, out for touchy!!
Is it good to have the accelerator that touchy? because i mean its REALLY touchy. Thanks for your feedback ill try that though, i kinda figured you would do that but everyone i asked told me that you couldnt so im glad i can. Thanks
Anyone else got ne feedback on my other ?'s i really need to know thanks.
Jon
Jon
I guess its really how you like it!! I like my my peddle touchy... its all up to the driver!!
Will it effect anything? Doesnt that mean that it will squeal the tires more?
