How much can you take off?
Compression ratio aside... how much can you deck the block or the head before things start to smack? It would namely be for BP.
- mitmaks
Re: How much can you take off?
no more than .060
That's actually a lot more than I was thinking... thanks for the reply.
- BuGS
Acually if you are looking for more displacement, Flyinmiata makes a kit so you can make a 1.8 to a 2.0.
That may be overbore and stroker kits that you are thinking of Clinton? I think that max overbore is more like .120"+ (3mm + ) on the BP from what I've read.
I just meant how much to take off surface of block and head. I'm a believer that the piston should be a lot closer to the head than it is.
- BuGS
Well my name is clayton not Clinton, gosh no. And ya the thing i am thinking of is the stoker kit from FlyingMiata. It brings the displacement up to 1995 CC. it looks like a great kit. And if you are going for N/A powe they have it with 11:1 compression. BUt i would go for the 9:1 and turbo the beast!
ahhhh crap... I really apologize for putting in the wrong name. I thought I had it straight in my head when I posted. I honestly didn't do it on purpose, I've just been half asleep all day...
Anyways, I'm going the turbo route and doing some head work on the engine I have. The turbo kit is being built by Turbine Tech, and the combustion chamber and port work is being done by myself.
I'm hoping the 1.8L will do me for a while though.
How much can you deck you say? let me tell you.. You lay on the deck and i will Knock you until you want to smack....my butt... come on you diiiiirty boy.
Does anybody speak english here???
Nobody is perfect, I am nobody, therefore... I am perfect.
English? It's all automotive jargon here.
and if you're Haggard like the big hairy dude in Harry Potter movie, I'm afraid I'm going to have to decline.
