On a 92 rs (thats the sohc l4 model), is it possible to swap in a VAF to replace the stupid restrictive MAF from a GS or something? I know you can get a 2nd gen rx-7 non turbo MAF and that they are bigger (3" opening instead of 1"), but f**k, I hate those things.
I want a 100% opening VAF as apposed to that square 1-3 inch opening that we are stuck with.
I KNOW that a lot of you RS owners would love to see this happen.
OH, and would it work with a turbo if you COULD swap it in?
Thanks a lot!
MAF to VAF???
- MX3-Freak
Re: MAF to VAF???
MAFS are less restricive in the meathod they measure air then VAFs...
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
- monty73741
Re: MAF to VAF???
the conversion that could be done would be the maf to map conversion like miatas
Jason Danaher
Please Help Support MX-3.com
- MX3-Freak
Re: MAF to VAF???
After a litte more thought, I realized you hada 92 RS. The B6-DE's (pre 94 RS's) used VAF's, not MAFS. So what would you accomplish again by "swapping to a VAF"? lol....used the Rx-7 MAF, it will give you slightly better airflow then the B6-ZE's came with stock.
Car Meanins:
Car Meanins:
Re: MAF to VAF???
Haha, I am sorry you guys... I have the trap door type, which ever that is. I want the straight through kind with much higher airflow.
Re: MAF to VAF???
I'm somewhat confused by this... are you saying that they sell a conversion kit for the miatas? If they do, it would be a direct bolt on for our Mx-3 since the stock miata meter is the same exact VAF that comes in our Mx....Originally posted by monty73741:
- MX3-Freak
Re: MAF to VAF???
In my opinion MAF's would be the ideal choice for any set up. They are the most accurate, and how much is a tinny wire going to affect your air flow?
For those of us with the b6-ZE (94+), unless you go above 6000k then the Rx-7 maf is a pointless upgrade. proof: link
I found this from another thread just started today in the 4cyl section.
<small>[ August 03, 2004, 08:29 PM: Message edited by: MX3-Freak ]</small>
Car Meanins:
Car Meanins:
