Has anyone here converted a set of probe headers to th fit the 1.6dohc , what modifications are required and how much of a performance gain was achieved?
Eugene L
1.6DOHC
N.S.canada
http://www.cardomain.com/memberpage/552384
Probe Headers
Re: Probe Headers
I wish i had a dyno of the before and after, but yes i have done it.
You have to port the header/head modistly to make them line up a little better and drill some new holes.
You also need to get the downpipe/flexpipe and have the exsats fixed as well
-torp.
I don't own a Mazda.
Re: Probe Headers
hey i got about 8 hp to the wheel ...says the dyno cant post the no scanner
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
Re: Probe Headers
they fit the bp>Originally posted by torpedan:
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: Probe Headers
So these probe 2.0l headers dont fit the 1.6dohc, but fit the 1.8 engine?
Eugene L
1.6DOHC
N.S.canada
Eugene L
1.6DOHC
N.S.canada
Re: Probe Headers
I am not sure what bp he has seen them fit but when i checked it against a gasket it didnt.
It worked with some modification for a the 1.6 dohc though
-torp.
- papa roached
Re: Probe Headers
i think the > was meant to be a ?
Re: Probe Headers
I just ordered a set of these headers and when I get them, I will have pics of the process of tweekin them to fit my 1.6dohc rs on my cardomain site. but if they take as long as my cf hood is to get here I might be adapting them to some sort of antigravity drive
Eugene L
1.6DOHC
N.S.canada
![Welder :welder:](./images/smilies/welder.gif)
Eugene L
1.6DOHC
N.S.canada
