i'm trying to fix my car in order to pass emission test 'cause my car's got oxides of nitrogen (NOx) failure. i think i had incorrect gap on spark plugs, so what's the correct gap for our car?
Well, if your air/fuel mixture is incorrect, then not muhc you can do about it. Your ECU takes care of all the mixture balancing.
But the correct spark plug gapping for the B series engine is .039 - .043
Stock 1995 RS - Creek Blue
Car Meanins:
the B6ZE is .039 - .043, the difference of .004 of an inch isnt going to make much of a difference. Hell, you couldnt get it that specifc without the help of a computer (a thousand of an inch is not visible to the naked eye...).
Car Meanins:
