how do you tkae this out ???
i'm try'n to take my guage cluster out and i can't seem to pull it out, like somthing is holding it in ??? i un screw qall the screws pull and nothing so if any one can help me please help !!!!!! thanxs !!
"get some!"
- papa roached
Re: how do you tkae this out ???
did you unhook the speedo cable from teh back of it
Thats exactly whats holding it. Reach your hand up directly behind the speedo and you will feel the cable.Originally posted by papa roached:
- atlantamx3
What model do you have? the SOHC or the DOHC?
If you have the SOHC, its a cable speedometer and you must unhook it at the tranny.
You will need a friend to help you out in order to unhook it unless you know exactly where it enters the tranny. Have your friend sit inside the car and tug gently on the cluster while you are looking in the engine bay at the firewall to see where its coming out at. Follow that wire down to the tranny and I think it just pulls out. I cant remember exactly what holds the cable in the tranny.
If you have the DOHC, its electronic and can be unhooked at the cluster.
Good luck!
Good luck!
- atlantamx3
If your screen name is right, then you have a 1992, which means you have the SOHC, and therefore, a cable speedometer.
- papa roached
i always unhooked mine from under the dash when i had my 92 RS
Yeah I have a 93 and I unhook it from under the dash too. Its not that hard to get to. Come on Perry I thought you knew better.
- atlantamx3
WTF??Originally posted by mx3TT:
Really??
Where is it at under there??
