i can get a 1995 DOHC for 200 bux with a blown tranny.. also can i use the tranny from my RS SOHC for the DOHC motor and what else would i need they r both 4cyl.. so i am thinking if ai can get this DOHC i can pull it junk the old body and Rebuild it then drop it in my RS and have more power...
should be a swap and drop from what i have read, just swap the engine, ECU, anything else i aint sure of
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
would someone please explain all that you have to do in this swap?
14" 5 spoke PRIME rims, GS spoiler,180 Watt Sony Head unit with a 4 Polk Audio EX series speakers, Kicker Solo Baric 8" sub, StrandTec custom Air system, Blue under dash neon tube, Blue windsheld wipernozzle LEDS,straght-through dual tip exhaust, Belive it or not but, I did a 0-60 in 7.23 seconds!
pull old motor, install new motor, pull old wire harness, install new one, install ecu and hook everything up
