valve tick
mazdasport
valve tick
I have just recently aquired a valve tick -- I was wondering how I can get rid of it or what I can do about it. Thanks in advance.
Jowga28
Re: valve tick
I think every on this whole board has had this experienced this problem I fund on my Mx-3 is that when I do a oil change is when the lose stops and it only comes back on my car when I need to perform another one. Hope that helps.
Life passes you by so fast, keep up,drive a Mazda(ZOOM,ZOOM).
mazdasport
Re: valve tick
Well..thats an easy fix -- Ill try that -- thanks
OsoSlo z28
Re: valve tick
there are plenty of "fixes" for the valve noise. the only "true" fix is to either replace the lifter or shim it. if you are using too thick of oil, it will sometimes clog up in the oil passage of the lifter. if it's a light case, you can grab some hydro-valve clean from mazda and it works pretty well.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
mazdasport
Re: valve tick
the tick went away -- I got an oil change and no more tick...thank god.
