why does it do this
wannabeaballer
why does it do this
It seems like whenever i mess with the intake like put a blower or anythnig that is supposed to give my hp, like my car i don't know if it gets to much air or not enough but like it kinda like shakes like it's trying to get air than it will stall. ;(
Re: why does it do this
You put a blower on your mx3??
My Cardomain site
My Cardomain site
wannabeaballer
yeah it like blow air back through i hoked it up with a swith.
quinn_seipp
...are you talking about one of those electric turbos? if you are then dude, pull that **** off, cause it doesn't work worth a ****.
130 hp and 1000 horsepower strong,
those pieces of **** are only supposed to be used at WOT.
1992 White MX3 1.6l SOHC
- For Sale - 105,000 miles / 3,000 miles on engine
- Original B6 Bored 2 Over
- Centerforce Dual Friction Clutch
- Short Shifter
- Cross Drilled and Slotted Rotors
- KYB GR-2 Shocks/Struts
- Steel Braided Front Brake Lines
- Reverse indiglo gauges and carbon fiber trim
- Front and Rear Strut Tower Bars
- 17" Sumitomo Tires on Anthracite/Chrome Loco Wheels
- Short Shifter
the problem is the fan is probably blocking air from getting into your engine, I would take it off immediately. Plus, there have been cases where the blades of the fan have broken off and ruined people's engines. Those things are gimmicky and never work. If you want extra power get a cold air intake or if you have a wad of cash to blow get nitrous our a turbo.
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
quinn_seipp
actually at WOT they would be just blocking air worse as they can't blow enough air.
wannabeaballer
alright thanx guys!!!!!
