trouble with my swap 1.8l protege in a rs 94
Re: trouble with my swap 1.8l protege in a rs 94
The computer can compensate for the lack of maf signal but the engine seems to loose all his power. Tried to clean the element but no effect still the same trouble. Him starting to wonder if him not going to swap a maf from a v6 has it work in the same way but him going to have to change the plug and change the wire implacement. Him also going to correct the trouble of the different resistance off the iac.
torpedan. If you got a Protege LX tranny, could you do me a favor as well? is the bellhousing the same on the pro lx as the mx-3 and what about transmission mounts, i reply would be greatly appreciated
Check out my ride on cardomain.com
http://members.cardomain.com/methaen
The bellhousing his the same the only difference his that there is two bolts in front of the bellhousing to engine that or not going to be use If it's a rs 94 (earlier i don't know). I put a mazda bp engine on a mx-3 rs transmission so the opposite should be good to.
The housings are diffrent i did not check if it was swappable though as of my mx-3 motor is now a paper weight.. the mounts are basically the same
-torp.
I don't own a Mazda.
I did this engine swap on my RS. Its a great swap I've put 11,000 miles on since late summer, and its flawless. Had a few problems to start with similar to yours. Here what I had to do, PUT THE ECU FROM THE PROTEGE IN... For me that fixed everything, made idle perfect, had a rev problem fixed that. About the MAF, one I had you could unplug and it would ilde good, and I found I needed a new MAF. Let me know if this works for you. You'll definitely be happy with the swap those who are doing it. 1st and 2nd gear rubber, yeah! Smooth up ovr 100 mph!! Hope this helps Later... A.J.
so you guys are saying that a transmission from a protege lx will fit in my 94 rs no problems?
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Jeff Zettler:
so you guys are saying that a transmission from a protege lx will fit in my 94 rs no problems?<hr></blockquote><p>Seems that 1.8 dohc and 1.6l dohc tranny are interchangeable.<p>1.8l dohc engine had a stronger tranny though.
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
If you have the tranny from the protege available to you, sounds like best to use it. I didn't so I used my tranny I had and put my 1.6 SOHC flywheel and clutch on the 1.8. Works great, sounds like I'm the only one who did it this way. Later A.J.
Machelski65 did you change the wire harness or did you let the one from the precidia. That my big trouble. I don't know if the computer his going to fit the precidia harness and i don't have a protege harness. For the computer i would have to buy a knew one has there are not many 1.8l 95 here in quebec
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by atila:
Machelski65 did you change the wire harness or did you let the one from the precidia. That my big trouble. I don't know if the computer his going to fit the precidia harness and i don't have a protege harness. For the computer i would have to buy a knew one has there are not many 1.8l 95 here in quebec<hr></blockquote><p>then get a escort gt ecu there everywhere
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Really the wireing harness shares a lot of similar componets but it would be best and easiest just to swap the whole harness and ecu..
-torp.
