Air / Fuel Gauge
Air / Fuel Gauge
hey guys,<P>Gonna hook up an air fuel gauge into my newly arrived gauge pod.. <P>Anyone done this before?? Need to know wires that should be run from oxygen sensor!<P>thanks<P>Tawheed
-=All that is gold does not glitter, not all those who wonder are lost=-
- jaydog5678
Re: Air / Fuel Gauge
Off the O2, black wire is signal, the other 2 white wires are ground and power. The black signal is where you need to tap into for the gauge to light up back and forth. Correct me if I'm wrong.
you can tap the signal off those wires. i got the sig from the wire going into the ecu. i believe it's a red wire with a blue stripe. can't remember. check the online shop manual.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
old topic, but same subject. i have my autometer a/f gauge. have the ground hooked up and i know the other wires except for oxygen sensor.. do i just take the o2 sensor wire and splice it and get the signal from there? im pretty sure because the signal comes as an electric current so it'll be safe to splice it and solder the wires together again correct?
- team slideways
- team slideways
its easier to connect it at the ECU. The wire was black/blue (terminal 2D) for me but i'm a v6er
Shaun Newman
i spliced the wire to the one from the throttle body ... if that made any sense
Sold my 95 RS "Little Peanut" but she will never be forgotten. ![Sad :(](./images/smilies/icon_sad.gif)
hmm throttle body? don't you mean header?
- team slideways
- team slideways
