b6t, bpt, bpd
b6t, bpt, bpd
Which engine is the easiest to swap, with the least amount of modifications? I have heard that the b6t has problems fitting under the hood.
1993 rs<BR>with fx designs body kit
Re: b6t, bpt, bpd
yeah, you'll have to cut a hole in your hood because the b6t sits straight up unlike the tilted mx-3 b6. the bpt and bpd are the same externally so it's the same installation. the only diff between the two is how much you want to spend. i believe the latter is the easiest.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
