I need the radiator neck thingy, its the thing that the radiator cap screws onto, it bolts onto something else. It has 2 bolts on each side.
I have a 92 V6.
WTB: 92' V6 radiator neck thingy
916 Blk MX3 V6
Re: WTB: 92' V6 radiator neck thingy
your probably better off just going to mazda and getting their replacement one, i had the plastic one on my car and it cracked and got worse and worse eventually overheating since it would boil out all the coolant, the oem stock one on a 92 is plastic, the replacement one they give you is aluminum , just buy the one from mazda and you wont have a problem with it again
sold the mx-3 , bought 04 gtp comp g , from the smallest v6 to one of the biggest 3800 s/c FTW
Does anyone know if I can get the same part off a Ford?
dealer wanted $36 for that little piece.
916 Blk MX3 V6
Dude, don't be so cheap!!!! That $36 can save you a lot more than if you don't fix it!!!! Don't forget to get the o-ring that goes under it, as it is usually all smashed and flat. Just tell them you want a cash ticket for the part and tell them you work at some repair shop in your town. That should take it to about $30 for that and the o-ring.
