Who knows if I can measure an ABS sensor when it's off the car ?
Is there a way to check if the sensor is still good?
Measuring ABS sensor
- WhiteFinish
- WhiteFinish
Re: Measuring ABS sensor
Who could help me out ?
- WhiteFinish
Must be somebody who knows...
The only thing you can do is a resistance check. I don't know the specs, but its not a full proof way to tell you if its still good or not. There is no full proof way to check with the sensor off the car.
- marcdh
There's a resistance range iirc around 1.5kohms. Possibly in workshop manual. Can't remember value but if they're all the same you will know they're fine. Have you pulled abs codes? I made a how to on ukmx3 years ago for that.
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
