![Image](http://i1331.photobucket.com/albums/w588/poseymx3/Mobile%20Uploads/20140520_121721_zpszhg8cqa0.jpg)
Can I Fix This¿?¿?
Can I Fix This¿?¿?
Re: Can I Fix This¿?¿?
http://mx-3.com/manuals/showimg.php?fil ... F2-007.gif
its one of the vacuum solenoids for your egr, your car will run fine without it but yes you will loose about 3-5mpg. In the meantime drive passively and you should be able to make up a good part of the difference in your driving style until you can locate a spare.
Try messaging Caleb on here, he has 2 spare v6 cars that should have one
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Yup that sux I was hopin itd be something I can fix before I leave in a few hrs...moderate driving is kinda not an option since ima be goin thru the mts..but ill figure it out when I get bak.
Removing EGR reduces MPG??
If you removed all of it and capped off the vacuum hoses it should still run fine.
1995 Eunos 30x KLZE
Yes it will still run fine as mine does, but yes you will hurt your total MPG running without one:RX8SE3P wrote:Removing EGR reduces MPG??
http://auto.howstuffworks.com/fuel-effi ... ation2.htm
Just make sure the EGR is closed and you'll be fine. If you need to pass an E test chances are without the egr working you'll probably fail as the ERG allows for a more complete HC burn.
Yea u have a Classic Rod Registrantion no smog required.
::UPDATE:: So I found one but it was broken too...mine were bolted directly on top of the manifold so I assumed all the others at the yard were gone...but I didnt know it was located out of site behind the TB so all check engine codes shpuld be alleviated by tomorrow but hell I cant comeplain I got the car for 250 bux couple months ago and have put 12K+ miles on it since...
