Front 5 lug upgrade
WhiteFinish
Front 5 lug upgrade
Post by WhiteFinish »
Who can I make happy with some front 5 lugs ?
They came of a 323 v6, due that I only needed the spindle.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
AaronTietje
Re: Front 5 lug upgrade
Post by AaronTietje »
I would be super happy if I could get my hands on a rear 5lug setup. :D
WhiteFinish
That's also an option, but not as easy as you would think.
Probably getting the complete rear set, than disassemble and sending it.
Worklog click
AaronTietje
I already have a 5lug front and would love to get the rear to match. Pm me a price on what the rear would cost.
Thanks.
MrMazda92
Post by MrMazda92 »
Aaron, do as Scott D. and I have, 1st gen Probe parts.
You'll prefer that if/when you need to replace things.
Post by Josh »
Yeah what bearing does the 323 v6 use? are they the same as the MX?
marcdh
Post by marcdh »
Same up front which is handy. Rears are plug and play with just bearing/hub assembly and the discs.
View Worklog
Post by Josh »
Hmm, this may be what I am looking for then. Are the two bolt holes for the brake caliper further apart than the MX3 spindles? If so I am interested.
AaronTietje
The only problem I have been having is I can't seem to find any probe rears :evil: Except one guy on PT wanted to sell me a rear set for 450. :?
MrMazda92
Post by MrMazda92 »
The 2nd gen prove rears work if you reduce the profile of the rear TTL bushing, and cut the sleeve down. Also makes energy bushings a perfect fit.
WhiteFinish
To make it clear, it's only the 5 lug.
You can switch this thing with your spindle + bearing
I do NOT sell the 323 spindle !
Worklog click
Post by Josh »
WhiteFinish wrote:To make it clear, it's only the 5 lug.
Well that makes sense now.
side question, do you know the spacing measurements between the caliper holes anyways ;)
MrMazda92
Post by MrMazda92 »
Josh, measure the Probe parts. They're identical...
If you need the measurements, I can run a tape to where my car is parked and check...
