NGK iridium plugs
- mitmaks
NGK iridium plugs
Anyone running these on their K8 car? Are they worth extra $$, do they improve anything or they just drain your wallet.
Re: NGK iridium plugs
I just dropped a set in my rebuilt KLZE. Figured since I went with Colt Cam regrinds, new HLAs, and will be installing a MSPNP, Coil Pack install/distributor delete, VAF delete (IAT install with the MSPNP), and lightweight flywheel, $50 or so bucks for a new set of plugs won't kill me...
Just started the engine the 1st time after rebuild Sat. Still way too early to know how things will work out together. Plugs are likely not going to make much difference...
Later!
Tim
Later!
Tim
MazdaMech
I got these for my K8:
http://www.ngksparkplugs.com/products/s ... p?mode=nml
Figured the engine wont be in it long hopefully my funds align well for my swap later this year. The autozone system says Mazda recommends Copper, so that's the main reason for these.
Own:
2012 Chevrolet Camaro LS
2006 Chevrolet Uplander LS
1999 Ford F-250 XLT LD
1992 Mazda MX-3 GS (Rescue from a poor handler) *In work*(Body, interior, (future - KL swap))
1987 Dodge Dakota LE
1983 Honda CX-650C +parts bike
Looking at:
TRYING TO FIND A MX-3 Daily! No Luck:-(
Looking at:
- mitmaks
Those are what came on these cars OEM
MazdaMech
The V-Power? I thought they came with the standard copper plugs?
Own:
Looking at:
Looking at:
benyandthejets
Pretty sure the car came with Coppers. Waste of money to buy iridium.
93 Blaze Red GS
- Josh
I am running the laser iridium's in my ZE (I know not a K8) but I love the heck out of them. I started averaging about 1.8 MPH better highway. I went against the general consensus on them, as I am kind of a rebel..
Thefez
I can atest to this i used NGK coppers didn't like them switched out for the iridiums much betterJosh wrote:I am running the laser iridium's in my ZE (I know not a K8) but I love the heck out of them. I started averaging about 1.8 MPH better highway. I went against the general consensus on them, as I am kind of a rebel..
- mazdaspeed23
NGK Iridium is well worth the money. they fire alot better and last longer. i have mine gapped at 42. i've had mine in my car for 6 years and they are still perfect although i've only put 32k's on the engine in years
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
- mitmaks
Are these laser iridiums? If so, how do you gap these, I thought they already come pregapped?mazdaspeed23 wrote:NGK Iridium is well worth the money. they fire alot better and last longer. i have mine gapped at 42. i've had mine in my car for 6 years and they are still perfect although i've only put 32k's on the engine in years
- mazdaspeed23
the iridium laser is for OEM application which come pregrapped they have dual precious metal, means iridium on the center tip and platium on the ground electrode.. I have the Iridium IX, which are a single precious metal aftermarket performance plug. They are designed for modified engines. With that being said the IX last to about 50 thous miles ( well should be changed, but dont have to be) the Laser ones last about 100 thous miles.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- Josh
Yes, pre-gaped. If you touch the contacts at all you can destroy them, do not re gap them.
In my ZE I used the Irridiums for the Probe FS 2.0, the Rx-8 only uses Irridium Lasers, and I decided to give those a try in the Xterra as well.
I run NGK BKR5E-11 in both of my ZE.
- Josh
Yep I am running the laser iridiums for the FS 2.0. Love them.Nd4SpdSe wrote:In my ZE I used the Irridiums for the Probe FS 2.0, the Rx-8 only uses Irridium Lasers, and I decided to give those a try in the Xterra as well.
