no fuel on my sparkplugs
lucifernl
Post by lucifernl »
hi mx lovers.
i had many problems with my klze.
but it isnt over yet.
my car was fine until i was home,then the trouble begon.
first i had no spark.
changed the disty-spark plugs and wires-hei module and wiring
i had no ecu trigger signal
cleared the earth points and now i have a ecu trigger signal and a spark.
try to started the car and it fires up.
runs rough and had no idle.
turned engine of and started again with a little trottle and the car started.
i was happy finaly it starts after 4 months there is progress.
but if i want to start my car again nothing happens and my spark plugs are dry.
checked the fuel pump and it works.
what can i do?
i beleving to think that this is the end of my mx3.
plz help me out ervery input is welcome
greetings from Holland.
kevin
alamo_kl
Re: no fuel on my sparkplugs
Post by alamo_kl »
Since the pump works, but no fuel is hitting the plugs, I would think it would be the injectors. Either bad injectors or wiring.
93 GS: KLZE, EBay headers and downpipe, "Custom" Intake, No Name exhaust, 15x7 Enkei Rpf1, Lotek Drops
09 Civic Si Sedan: K&N Typhoon intake, Skunk2 Megapower Cat-back
14 Stryker: Stock as F**K
Check that your VAF is completely plugged in. Check that your crank sensor plug is completely plugged in as well. In fact check every plug you can see including your injector plug and make sure they're all fully engaged and there's no corrosion in the plugs.
