hi all
i have this problem for 2 months now.
and yesterday started the car whas sitting still for 2 months,and
started right up strange whas broken left alone.
the car started but stumbles the problem is back
car idles down and stops.
restart the klze no life left.
get no ecu trigger G to hei---no spark
what i have already done
new hei and rewired
swapped kf01 distys
new rotor arm
new disty cap
sparkplugs and ingnition leads.l
swapped ecu
the car is a mx-3 klze longneck
plz help me
thanks!
greetings kevin
Ecu Trigger signal Help!!!
Re: Ecu Trigger signal Help!!!
i have looked for a broken wire from 3G(ecu) to the hei
the wire is good and not broken.
the ecu makes the g signal
but how does he make it?
im desperate!!
greetings kevin
im desperate!!
greetings kevin
